S shopsterhelp Aug 23, 2018 14 0 10 Sep 3, 2018 #1 When im downloading windows it says that i need a gtp driver and i have a mbr what should i do to fix this problem
Solution SkyNetRising Sep 3, 2018 Use Diskpart utility. It has all the necessary commands. clean - cleans selected drive convert - converts drive partitioning format to mbr or gpt. But those are somewhat advanced commands. If used inappropriately, will make you loose your data.
SkyNetRising Titan Jan 4, 2016 32,869 4,860 126,640 Sep 3, 2018 #2 Can you show a screenshot, where it says that? Upvote 0 Downvote
SkyNetRising Titan Jan 4, 2016 32,869 4,860 126,640 Sep 3, 2018 #4 Ok. Then show it. Upvote 0 Downvote
S shopsterhelp Aug 23, 2018 14 0 10 Sep 3, 2018 #5 wait can’t but do you know how to convert. MBR to GTP Upvote 0 Downvote
SkyNetRising Titan Jan 4, 2016 32,869 4,860 126,640 Sep 3, 2018 Solution #8 Use Diskpart utility. It has all the necessary commands. clean - cleans selected drive convert - converts drive partitioning format to mbr or gpt. But those are somewhat advanced commands. If used inappropriately, will make you loose your data. Upvote 0 Downvote Solution
