i need help with my 3.2GHZ
knifetheglitter
19
hi everyone, i need some help with my new setup. I just upgraded my system to a 3.2 from a 1.8@2.5 with new from (old 2700) to new ocz pc3500. when i do 3dmark03 tests and aquamark tests, i get only like 300 more points, which is a little disapointing. I dont know if im not overclocking my ram right, or maybe its my 3d card or something. I NEED HELP!
RIG:
intel 3.2 prescott @ 3.6
asus p4p800-e deluxe mobo
1 gig (2x512) ocz pc3500 dual channel
bfg 5900 128mb flashed to 5950 ultra (450, 950)
Zalman CNPS70000A-Cu heatsink/fan
wschuerm
336
??????? Have u reinstalled ur system yet, maybe theres to much clutter on there to bench properly. On the other hand, this bench is evry video card dependant also.
SL6EF OC's GOOD
RichPLS
Champion
So you basically went from a P4-2700 to a P4-3200?
That is only a 500mhz increase. Less than a 20-percent jump.
Noticable, not kickass...
_____________________________________________
<font color=red> And the sign says "You got to have a membership card to get inside" Huh
So I got me a pen and paper And I made up my own little sign </font color=red>
Clob
1,317
According to your sig its at 3.6 now. Was there any more difference?
"If youre paddling upstream in a canoe and a
wheel falls off, how many pancakes fit in a doghouse? None! Icecream doesn't have bones!!!"
"Battling Gimps and Dimbulbs HERE at THGC"
Crashman
Polypheme
Former Staff
3DMark 03 is not very CPU dependant. In fact, early test showed it performing better with a 9700 Pro on a PII 300 than on a Ti4200 with a P4 3GHz or something insane like that. It's almost totally video card dependant.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
knifetheglitter
19
i had to put it back down to 220 fsb because it overheated way too much. so my ram is at 2.5-3-3-5 @ 220 with a 1:1 ratio, my clock is at 3.52ghz, and my flashed fx5900 is at 450/950. its not a bad rig, but my 3dmark03 scores are like 6200ish, and my aquamarks are like 4200ish. i just think that it should be higher.
Blasphemy
97
Putting better RAM and O/Cing the CPU won't run up your 3DMark scores very much, if you want better 3DMark scores you'll need to go out and buy a new video card. If you want to benchmark the CPU and RAM then use SiSoftware Sandra benchmarks
AMD Athlon XP 2100+ stock
Asus A7N8X-E Deluxe
1GB generic RAM
ATI Radeon 9700 Pro 360/335
