I need help with my build
The stock has the paste applied on it out of the box and the 212 Evo is the same or then it comes with a tube of its own, I'm not 100% sure. Either way, you won't need the additional paste.
I think you should go with that build, but ditch the motherboard and get a cheap B85 one. Z87 motherboards can overclock (the CPU can't) and they support SLI, which makes them a lot more expensive.
Looks good, just get rid of the thermal paste :D
By the way, I just noticed you could save money by getting this power supply, which is actually a little bit better. The only downside is that it isn't semi-modular (meaning it has no removable cables).
andrei65
1,330
I prefer semi-modular psu's , because the of the fact that i have to rearrange every cable in the back of the case . Anyway thank you , i don't need any more help . I'll let my mother choose one of these builds
EDIT : Ok so i modified almost everything and i ended up purchasing all these parts :
http://pcpartpicker.com/p/3s0lR
I'll maybe start doing some photoshop stuff , so i decided i'll get 16GB of ram and an unlocked i7-4770K .
I'm getting everything the next week , i'll tell you how it turned out
