[SOLVED] I Need Help with my Build
Oct 4, 2019
What do I do if the only part of my build that isn't being powered on is my graphics card? The GPU I have is the NVidia GeForce 1660 Ti, the CPU is a Ryzen 5 2600, and the power supply I'm using has around 600 watts in it. My motherboard is an ATX board and it has 16 gigabytes of RAM attached to it.
white.a.drew
Respectable
Oct 14, 2017
843
49
2,240
57
Have you checked to see if the gpu is plugged in all the way, if the 6 pin power ports dont get plugged in all the way that can cause a problem. It could have some gpu's are a 6+2 pin power connector. Can also be a 6x6, or 6+2 +6, or even 6+2 +6+2 basically a 8 pin.
white.a.drew
Respectable
Oct 14, 2017
843
49
2,240
57
Sep 15, 2019
86
8
65
14
Check that if the power pins are connected to the graphics card. If the power supply is modular and change the power cable going into the graphics card if it still doesnt power on then use this new graphics card on your friends system and check if it works. Trail and error it is. Does your system fully powers on?
Oct 4, 2019
I use a 6+2 connector and I haven't checked whether or not it's completely plugged into the GPU or the power supply.
Reactions: white.a.drew
