Question I need help with my cat 5 to USB extenders
Grobe
810
34
19,390
103
Can you be more specific about your setup?
  • CAT5 cable length
  • USB hub model (if any)
  • Other pheriperals
And - does the keyboard operate normally if that is the only device connected via cat5 cable?
pearce_pc
77
  • CAT5 cable length
  • Other pheriperals
The cable length would be 15 metres
There is no hub just running on the adapters and cable
Other peripherals are mouse and headphones. Them two work fine it's just the keyboard that wont
hang-the-9
