I need help with my first pc build...
introvertednumnut
23
Here are my components:
-Western Digital 1 TB SATA III 7200 RPM 64 MB Cache Bulk/OEM Desktop Hard Drive, Black, WD1003FZEX
-Samsung Electronics 24x DVDR 5.25-Inch Optical Drive SH-224DB/RSBS
-AMD Athlon Multi Core Processor AD760KWOHLBOX, 760K Richland 3.8GHz Socket FM2 100W
-EVGA GeForce GTX 750 2GB FTW with EVGA ACX Cooling, GDDR5 128bit, Dual-Link DVI-I, HDMI,DP Graphics Cards 02G-P4-2758-KR
-Crucial Ballistix Sport Very Low Profile 8GB Single DDR3-1600 1.35V UDIMM 240-Pin Memory Module BLS8G3D1609ES2LX0
-MSI A78M-E35 FM2+ / FM2 AMD A78 (Bolton D3) HDMI SATA 6Gb/s USB 3.0 Micro ATX AMD Motherboard
-Corsair Builder Series CX 500 Watt ATX/EPS 80 PLUS (CX500)
-Corsair Carbide Series SPEC-01 Mid Tower Gaming Case CC-9011050-WW
-Windows 8.1 System Builder OEM DVD 64-Bit
I'm almost done with my very first pc build. When I turn it on it goes into the bios (which is normal) and the cpu temperature quickly increases. Within 2 - 5 minutes it would be at around 65 - 69 degrees c. This cpu has pre-applied thermal paste and I am using the cpu cooler that came with the cpu. I do not know what is causing this over-heating. There may be a problem with the paste, heatsink, or the cables getting in the way? Is 500w too much or too little? All/any help is appreciated!
get the spec 2 case instead of spec 1 spec 2 has 2 fans additional 1 fan more than spec 1 and the price is almost same for the 2......an aftermarket cooler would be good if u OC your processor now or later....amd stock heatsink are very cheaply made and not at all good for handling high temperature.....so get a coolermaster hyper t3x its about 16 $ i would also have suggested u the hyper 212 evo but your case has 158 mm cpu clearance and the hyper 212 is 159 mm in height so if it fits by any chance it would be a very tight fit.......
