As mentioned you need to buy a key. You must activate otherwise Windows will cease to function. It should tell you how many days you habe left to activate.
If you cant afford Windows, perhaps you should look at Linux as it is free.
As for activation, if you do it, it will activate or it wont. Worst case you get your friends key blacklisted and his version wont work either (unlikely though)
