I need help with my pc
Joost_1
Commendable
Jun 3, 2016
4
hello all,
i have a remotely old pc, and am thinking about upgrading it in the near future.
as of now my specs are
Intel i5 3350p@3100mhz
6gb ram@1600mhz(1x4gb, 1x2gb)
motherboard: asus cm6330_cm6630_cm6730_cm6830
psu; no idea tbh, but its old.
gpu: gt 620 2gb
i was thinking about buying an Asus GTX750TI-OC-2GD5 and as a power supply a Corsair Builder CX430 Bronze. (im on a pretty limited budget)
however im not sure if there will be some issues with this motherboard and the gpu, or with anything at all.
also im not sure if I can just remove all the cables from the old psu, plug the new one in, exchange the old for the new gpu, and thats it, or i have to do some other things aswell.
I would really appreciate it if someone helped me out.
That GPU should be fine with your CPU. Swapping them out is really all it will take. Just make sure to update the video driver afterwards.
