I need help with my power supply
well i do plan on getting a water cooler and over clocking and thats why i got a k series so i might need more then the 450, thanks for the response though, it did help
Well a good budget cooler that performs very close to the H60 is the Hyper 212.
Take a look at this, the hyper 212 trails the H70, the H60 should be below or above it but very close by. My guess would be below since I own the Kuhler 620 and it is almost equal to the H60.
http://www.hardwaresecrets.com/imageview.php?image=39719
Edit: According to this foreign review, the Kuhler 620 does perform just a bit worse by .1 of a degree and the hyper 212 evo is equal to it.
http://translate.googleusercontent.com/translate_c?depth=1&hl=en&prev=/search%3Fq%3Dh60%2Bor%2B620%26hl%3Den%26prmd%3Divnsfd&rurl=translate.google.com&sl=sv&u=http://www.sweclockers.com/recension/13538-antec-kuhler-h2o-620-och-corsair-h60/5&usg=ALkJrhjz2Z8VBLDPpAD8sqLw1zKk8Lwaig#pagehead
