Firstly, I apologize for my weak English.
I recently purchased a used RTX 3080 10GB Aorus Master, and I'm having some problems with it.
When doing benchmark tests or even in games I notice that even though it is at 100% use, it is consuming less energy than it should, staying in the 60% range and because of this I have had low fps.
When running a furmark for example, in the first two seconds of the test it manages to pull the TDP to 90%+, but soon it drops to 60% and drops until it reaches 50% of energy consumption, although it is at 100% of its use.
I've tried several things like:
Test Windows 11
Change the bios switch to oc/silent on the video card
Test on another MB and PSU (showed the same defects)
I honestly don't know what else I can do
Below is a screenshot of it on the furmark after a few seconds of testing.
how to see at max fps, in the initial seconds it reaches 451 fps, after that it reaches a mediocre 200-240fps
Test Windows 11
