Question I need help with my ssd. mbr2gpt
Charles Lalonde
70
Im trying to convert my drive from mbr to gpt and it's not working.
Basically every time I run checkdisk it finds 0 errors, 0 bad sectors but everytime I check disk it says there an error...
I've used other software, finds 0 errors.
So I cant shrink the partition to proceed....
Create another bootloader at the end of the drive and delete original 100MB bootloader.
Execute from elevated command prompt. Regular command prompt will give error on last step.
diskpart
list disk
select disk 1
create partition primary size=150
format fs=ntfs quick
assign letter=H
active
exit
bcdboot c:\windows /s H:
Do not reboot, if there were errors. Show screenshot.
If there were no errors, then reboot.
Now partition at the end of drive should be marked as system,active.
Then delete 100mb partition at the beginning of the drive. Retry mbr2gpt after this.
diskpart
list disk
select disk 1
assign letter=H
active
exit
after assign letter=h View: https://imgur.com/6eAWphO
should i format? ..Oh wait a sec, I forgot to do this step format fs=ntfs quick
