I need help with my system
Leonbidis
29
Well my specs are
i7 4790k @4,40 ghz
corsair xms3 8gb @2000mhz
gigabyte z97x gaming 3
thermaltake SMART SE 730w
Corsair Graphite 730t
GTX 970 Windforce gaming1
SSD SanDisk 120GB
256GB HDD (its really old i dont know its name 😛 )
My case fits like 7 total case fans. Will my mobo and psu be able to power up all 7 fans if i put 7 fans in my case at some point? My mobo has 3 system fans connectors will i need extra psu cables to put more than 3 fans? I really dont know what to do help 🙁
I don't think you'll ever need to use all 7 fan mounts. I personally go with 2 intake and 1 exhaust for my case. It's whisper quiet on idle, but of course, it will make some noise while under hardware intensive applications.
If you don't have enough fan connectors on your motherboard, you can buy a Molex - 3pin adapter for your PSU. However, you won't have any control over the speed of the fans you connect to the power supply.
yeah but i think that all 4pin exits of my psu are taken from hard drives and cd/dvd roms
