I need help with port forwarding
RedDevil_123
Commendable
Mar 17, 2016
4
My router is D-link DSL 2750U. I need to open ports for playing fifa 16 on ps4. so i went to the router page , assigned the ports, but when i checked on http://www.yougetsignal.com/tools/open-ports/ , ports were closed. please help, suggest some troubleshooting methods
When setting up ports to port forward for a console or pc game.
Input the IP the Ps4 console was given by the router.
Select the correct type of protocol TCP, or UDP
Input each port you need to open Ie: from : 23500 - to: 23500.
Make a rule for each port you need to open and the protocol type it requires. TCP or UDP.
And give each port forward a name tag ie: PS4 FIFA 1, 2,3 ect.
apply each setting when done, move on to the next port to open. clicking apply after each entry.
Find the hardware firewall of your router, if the security setting is set to High.
You need to change it to medium settings at least.
Make sure Upnp mode in the router is enabled.
Bellow is a table of ports to open in the router for fifa 2016 on the Ps4.
Make...
Make sure you select the right protocol for the port number entered.
Each port Listed must have a single rule for it
Example : Name: Protocol type: Port to open from and too. so you would put 3074 for the start and 3074 for the ending port range. IP of Ps4 given or assigned to it by the router.
PlayStation 4 Protocol UDP: 3074, 3478-3479, 3659, 6000
TCP: 80, 443, 1935, 3478-3480, 3659, 10000-10099, 42127
How do I make sure upnp mode is enabled ? And how do I check firewall settings for router?
@shaun o https://drive.google.com/file/d/0Bywf9jUMHukdNkFGTXNiMF...
These are the options that I can see
