Question I need help with power supply choice
ppdemo
128
Hello everyone, I need opinions on certified and most convenient and cheaper power supply for this 4th generation equipment.
It will not use dedicated gpu. It will use the integrated gpu of the cpu. the use is mostly homely , internet browsing and multitask on some ocassions
The components in question are:
i7 4790k 4.4ghz at 1.140v
asus z97a
ram 16gb ddr3 sniper 2400mhz 2x8
hdd 7200rpm 1 tb
Clarification: I used it with an evga 850w g2 but because I used it with a gtx 1080ti, now that the gpu is removed and it will not be for game or render, it is because I need a source that works properly, that of the necessary, fair watts, and That is the cheapest recommended in quality price.
