maybe a 2400, i am looking to buy one and put an rx 580 and maybe replace the power supplyDepends on how "old" the i5 is? could be DDR4 or DDR3. if you have some idea of which i5, then we can help better.
thanks i will be sure to take some ddr3 and also what is mhz on ram? is it importantFirst to 4th gen=DDR3
5th gen=DDR3L
6th gen=DDR3L/DDR4
7th to 10th gen=DDR4
For the i5-2400 then DDR3 @1333mhz is fine and probably what most boards will support although 1600mh may work as well. I doubt you'd notice a performance difference between the two so just grab whatever is cheaper.thanks i will be sure to take some ddr3 and also what is mhz on ram? is it important
thanks alot, i appreciate you helping me, have a nice dayFor the i5-2400 then DDR3 @1333mhz is fine and probably what most boards will support although 1600mh may work as well. I doubt you'd notice a performance difference between the two so just grab whatever is cheaper.
