I need help with rosewill blackhawk case
nichijoke
18
Can someone tell me how to remove the two front fans? The 3.5 bay cages are blocking it and I don't know what to do.
I can't find the manual online - but from experience - the front panel should be removable. There should either be 4-6 screws that hold it in, or 4-6 clips that let it "snap in". If it has the clips, if you release the plastic clip with your finger, the front panel assembly should come right out.
