I need help with the front panel connections!
DGPILOT
7
I dont understand how my connections work,
there is the block that has the small ones connected, but then theres another one, on the side shown in the image it reads (top-bottom) PSW, PSW, PLED-,PLED+
Then on the other side; HDD+,HDD-,RSET,RSET
PLEASE help, i can connect everything to my board? motherboard is a Asus M4A87TD!
Thanks
oh and sorry the image is back to front :(
corrinavatan
20
From the looks of your pic, maybe you started connecting things without reading them?
Unplug everything from the white piece. Now, plug the BIG black piece into the white piece: the pins should line up with the holes, as well as the written descriptions should match up with each other. You might have leftover pins that aren't used by the big black piece.
Then, once you have that settled, you need to look at the wires you have remaining, and match those to the descriptions given on the white piece.
If you have wires left over that you can't seem to find a place that matches on the white piece, check for pins next to where the white piece plugs in; sometimes there are additional pins nearby for cases that have a lot of do-dads on the front.
biscuitasylum
194
Ouch, Sorry Moderator, don't ever tell an audio engineer that polarity to a speaker doesn't mater. You'll give them a heart attack. You almost gave me a heart attack when I read that, yes, I'm an audio engineer. :pt1cable: :lol:
DGPILOT
7
Im pretty sure the "big black block" must be for a different style of "white block" as after studying the black one more closely, my case doesnt have a power LED, and i can plug the HDD led in on its own, so i guess its ok then?
What is your mobo model?
You are correct. They stuck them all together to make it "easier" to plug in, but because all boards aren't laid out like that had to include the individual connectors for compatibility. if you look you'll see the same wires are going to the same connections. completely ignore the combined black connector and just follow the block Asus included.
That being said are you using a really old or weird case? I can't think of any header block that would one up with the large black connector.
DGPILOT
7
It's not old, its a brand new model but im on a tight budget so its not a popular brand, its sorta made to be compatible with anything, thanks for your replys, it is much appreciated, escpecially to get a good answer within the day
DGPILOT
7
I would never say anything like that to an audio engineer, technician, or knowledgeable amateur when we were talking about loudspeakers.
In this forum and this thread, context and picture indicate that we are obviously talking about the small speaker or piezo-electric device that plugs into the motherboard to generate audible beeps as the system POST's or tries to POST. :)
In this case, polarity does not matter.
DG, many cases (for example Antecs) with illuminated fans do not have power LED's.
corrinavatan
20
My CoolerMaster Storm Enforcer came with the same connector headers pictured.
biscuitasylum
194
I was just giving you a little poopy. :pt1cable: :kaola:
