i need help
TheNeonWhiteOne
20
I'm looking for a decent gpu that will work with my system under $200
i was looking at the gtx 650 ti boost
my system is a budget pc from ironside computers
AMD Processor - AMD Athlon x4 750K 3.4GHz, 4.0GHZ Turbo (Quad Core)
AMD Motherboard - MSI FM2-A55M-E33 {2 DDR3 Slots}
Memory - 4GB (2x4GB) DDR3 1600MHz
Primary Hard Drive - 500GB 7200RPM
Graphics Card - AMD Radeon 6670 1GB
Power Supply - Cooler Master 400 Watt
Operating System - Windows 8.1 64 Bit
the best gpu that I can find for my system with getting a new psu is the gtx 650 ti boost
my budget for a gpu is $200. if there is a cheap gpu that works well and a better psu under $200 combined that works to but i doubt it.
I want to play bf4 better, right now i get about 30fps on low settings at 1280 x 720
but the R9 270 is $200 so i cant get a psu as well
Either PSU is fine, although I believe EVGA is a more reputable brand. Won't hurt to save 10 bucks and pick the Corsair.
R9 270 = 4% increase 180 dollars
GTX 660 = 4% decrease 160 dollars
did you mean 660?
Yes, sorry. GTX 660
but isn't BF4 more optimized for AMD cards so would it be more than 4% increase on BF4. what fps would i get on BF4 on the different settings at 1920 x 1080
yes , 4% is on average , out of 18 games tested
Battlefield 4 1080p Ultra settings, No AA
NOTE: The PNY GTX 660 comes with a free copy of Assassin's Creed: Black Flag + $50 off Nvidia Shield.
such a hard decision i want the R9 270 performance but i want the extra things that the 660 come with
Dont worry . They both are awesome.
well i want AC4 and shadowplay with the 660 but i dont care about nvidia shield. and white cat are saying i should also get a new psu with the R9 270. and can i see a graph of the two on other games
Check this GPU
Palit GTX 760 jetstream 2gb.
