I need help
Drcola
69
I was stupid and decided to buy a new gpu to a old pc that is bad. I bought a Msi radeon r9 290 4gb with a new power supply, I need help with parts if i had to build a new pc , I have the Gpu,Power Supply,1tb hdd,8gb of ddr3 ram.
So what part should i use for the following things ; Cpu,Motherboard,Case,Fans And sound card (Correct me if i need more parts.) And my budget is about 750usd or maybe more.
4690K, Asus Z97 Hero, CM HAF 912 case - that's about $500, will also prob want a CPU cooler, look at the Hyper 212 EVO about $35, the Hero has very good sound so prob don't even need a sound card (I don't use one with my Hero, in Sig)
Is this the snipers ? ; http://www.128bit.se/article.php?id=314232
and is this setup going to work :
Storage:1862GB Seagate ST2000DM001(2tb) .
Ram:2x4GB 1866 Snipers.
GPU:Msi Radeon R9 290 4GB.
CPU:i5 4690k
Motherboard:MAXIMUS VII HERO (z97 hero)
Case: Cooler Master HAF 912 Advanced
Fan: Hyper 212 EVO
power supply: Cooler Master G650M (650W Plus Bronze)
Running Dual Monitors ?
