I need help
Joenamcoutinho
Commendable
Mar 15, 2016
I have a laptop that used to share network through ethernet cable to my desktop . After a month it gave an error on my laptop "ethernet exiting pxe rom " and had to reinstall windows 7 now whenever I share ICS my Lan no Internet access and my wireless network no Internet access . When I troubleshoot Lan "no valid ip" . But when ICS is unchecked my wifi works . But can't share to my pc ....plss help
Most likely you have overlooked some necessary setting. Especially after having to reinstall Windows 7.
First double check the adapters' settings.
Failing anything there start over.
Here is a link that will help.
http://www.online-tech-tips.com/computer-tips/share-internet-connection-windows/
(There are other links and tutorials as well.)
Just work carefully as you go through the ICS set up process. Keep track of the IP addresses and subnet masks.
