I need Help!
woodsoul
9
I just a bought a new power supply (http://www.amazon.com/Sentey-Bronze-Certified-Supply-MBP750-HM/dp/B00SN7CGAO/ref=sr_1_7?s=pc&srs=7725630011&ie=UTF8&qid=1460594454&sr=1-7&keywords=sentey) and after I installed it I keep getting a message saying Reboot and Select proper Boot device or Insert Media in selected Boot device and press a key. Did I do something wrong?
FIXED!!!!!!!!!!!!!!!!!!
When I first installed the new power supply I kept the same power cable for my graphics card and hdd after I switched those with the cables that my power supply came with it worked perfectly.
My hdd is fine and it is 1st priority but, when I switch back to my old power supply it works it is only with my new power supply that this happens.
