I need help
Joee__B
For roughly 1 year now , I have had a hacker that that I believe is from China. He puts viruses in my pc and set himself up as admin ..which is new ...thought I had that blocked. He is being a pain in the arse. Is there a way I can take back my admin rights and block him from getting into my pc ? OS is Windows 10 which was upgraded from 8.
I would suggest doing a clean install and then once its installed use a good anti virus/firewall like Bitdefender Free which may keep him off your PC. Comodo isn't bad either
backup everything you want to save
download the Windows 10 media creation tool and use it to make a win 10 installer on USB
change boot order in BIOS so USB is first, hdd second
boot from installer
follow this guide: http://www.tenforums.com/tutorials/1950-windows-10-clean-install.html
when you reach screen asking for licence, click "I don't have a key" and win 10 will continue to install and reactivate once finished
On the screen where you choose where to install win 10, if it gives you an error about GPT drives, delete all the partitions on...
boot from installer
On the screen where you choose where to install win 10, if it gives you an error about GPT drives, delete all the partitions on the hdd and press next. If it still gives error, cancel out of the installer and restart PC and start installer again, it will accept next on that screen this time (some PC just need a restart here)
