I Need Help
Lucaz_70
58
Hey Im making a build and im not sure what to change? i would like to take about $200 off but i dont know what to change. i dont want to change the mother board, graphics card or the cpu. i need a white case and this is for vr and other high demanding games. if i was going to keep this build how long would the computer be up to date (play most games no lag). Thx. do i need to buy anymore fans and/or cooling?
PCPartPicker part list: https://au.pcpartpicker.com/list/bMJyBP
Price breakdown by merchant: https://au.pcpartpicker.com/list/bMJyBP/by_merchant/
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor ($468.00 @ Centre Com)
CPU Cooler: Cooler Master Hyper 212X 82.9 CFM CPU Cooler ($49.00 @ Umart)
Thermal Compound: Prolimatech PK-Zero 600g Thermal Paste
Motherboard: MSI Z270M MORTAR Micro ATX LGA1151 Motherboard ($179.30 @ Skycomp Technology)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2133 Memory ($149.00 @ Umart)
Storage: Western Digital Blue 2TB 3.5" 5400RPM Internal Hard Drive ($93.00 @ Shopping Express)
Video Card: EVGA GeForce GTX 1080 Ti 11GB Founder Edition Video Card ($999.00 @ PCCaseGear)
Case: NZXT S340 Elite (White) ATX Mid Tower Case ($149.00 @ IJK)
Power Supply: Silverstone Strider 600W 80+ Silver Certified Fully-Modular ATX Power Supply ($109.00 @ PCCaseGear)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($129.00 @ IJK)
Monitor: Asus VP228H 21.5" 1920x1080 60Hz Monitor ($165.00 @ Mwave Australia)
Total: $2654.30
Generated by PCPartPicker 2017-05-05 20:07 AEST+1000
- Not such a good choice of a cooler, especially with an unlocked CPU, since you'll probably be overclocking.
- Pretty slow RAM for such a build.
- Expensive build, no SSD?
- 5400 RPM HDD?
- Not such a good choice on the power supply, again considering your budget.
- 1080p on a 1080 TI!?
Any good idea for a cooler?
I know i dont have much ram ill change to 32gb
Should i Change to ssd i need 1tb?
What does 5400 RPM HDD mean?
What power supply should i get?
and its a 1080 TI
To knock a few bucks off:
Memory: GeIL 16GB (4 x 4GB) DDR4-2800 Memory ($119.00 @ Scorptec)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($94.00 @ Shopping Express)
Case: Phanteks ECLIPSE P400S ATX Mid Tower Case ($119.00 @ PCCaseGear)
Power Supply: Fractal Design Edison M 550W 80+ Gold Certified Semi-Modular ATX Power Supply ($109.00 @ Mwave Australia)
Total: $2595.30
Generated by PCPartPicker 2017-05-05 20:49 AEST+1000
However optimised I'd go for that and meet the budget target:
CPU Cooler: CRYORIG H5 Universal 65.0 CFM CPU Cooler ($69.00 @ PCCaseGear)
Motherboard: ASRock Z270 Pro4 ATX LGA1151 Motherboard ($169.00 @ Mwave Australia)
Video Card: Gigabyte GeForce GTX 1080 8GB WINDFORCE OC 8G Video Card ($699.00 @ PCCaseGear)
Total: $2305.00
Generated by PCPartPicker 2017-05-05 20:52 AEST+1000
- An H7 would perform identically for cheaper and has zero ram interference. If you can spend a bit extra go for Cryorig H5 Ultimate. But that depends on your overclocks, if you're willing to just apply a moderate overclock then the H7 will be enough, if higher then H5 Ultimate will be a good choice.
- I am talking about RAM speeds, stupid to spend so high on the rest but not on the RAM.
- Yes, for games 1 TB is enough and you'll get extra for an SSD, but you need to go with at least a 240 GB if you wanna store a few games.
- RPM means revolutions per minute, more simple it is pretty much the speed of the HDD and higher is better in this case. 7200 RPM is around 33% faster than 5400 RPM.
- SeaSonic SSRM 550w if you can, Seasonic Sii12 520w if lower budget.
- That's what I said.
OK thx, what ram do you recomend, im looking for 16gb and very fast. here is my build... do i need anything else like fans or cooling or is this the complete build?
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($64.00 @ Shopping Express)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply ($135.30 @ Skycomp Technology)
Total: $2522.60
Generated by PCPartPicker 2017-05-05 21:17 AEST+1000
Memory: G.Skill Trident Z 16GB (2 x 8GB) DDR4-3200 Memory ($172.00 @ Umart)
Storage: Kingston HyperX Fury 240GB 2.5" Solid State Drive ($115.00 @ Scorptec)
Video Card: Asus GeForce GTX 1080 8GB ROG STRIX Video Card ($839.00 @ Centre Com)
Case: Corsair 200R ATX Mid Tower Case ($81.00 @ Shopping Express)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply ($105.60 @ Skycomp Technology)
Monitor: AOC I2279VWHE 21.5" 1920x1080 60Hz Monitor ($149.00 @ Scorptec)
Total: $2539.60
Generated by PCPartPicker 2017-05-05 21:25 AEST+1000
