I need HELP!!!
Apr 14, 2018
19
I need help, I built a Gaming PC and I am not getting the performance I was expecting. On YouTube benchmarks people have the same build but are getting substantially more frames.
I have a AMD FX-6300
Gigabyte 970A-DS3P - MOBO
EVGA 1060 3GB Graphics CARD
8gb RAM DDR3 1866MHZ
Seagate Caviar 7200 RPM
430W EVGA power supply
Please Help
What are your *exact* frames on what *specific* games and what are the YouTube videos you're directly comparing with? It's hard to provide much help without knowing all the details of a problem.
As Wolf notes, there are a lot of people who like to play games with FPS on YouTube video, you should only trust them ones from the most impeccable sources. Give me an hour and I can fire up Adobe CS and make a video showing myself getting 120 fps playing Witcher 3 on a Commodore 64.
Even on youtube one of the uploaders said this in the video description, "I think its safe to say the FX-6300 is just not good enough for modern games anymore. Even at a stable 4.4GHz, it can't keep up with a mid-range GPU like the 1060. It's a shame because the 1060 is such an awesome card and is capable of high performance (especially when overclocked) but this CPU is holding it back."
https://www.youtube.com/watch?v=hWv3mH96RVs
For example I enjoy Fortnite and this person is getting 60 frames on max setting where I get 40 frames on all low https://www.youtube.com/watch?v=1zqyyjyKIG4
Im running same gpu clock but only 3.5 on cpu because I have a stock cooler, and no matter what settings ingame I cant seem to get out of the 40-50 frame range and in shotgun battles it goes down to 15-20
no im at 150 core 300 vram sorry for the mistake
Do you have any other tips to increase at least some performance because I dont think no OC should make that big of a difference. Plus I was watching a fortnite benchmark and the guy was getting substantially more frames on epic settings so I dont think OC will make big difference. If you have any other tips you could offer I would greatly appreciate that.
MERGED QUESTION
Question from arvindhillon : "I need HELP!!"
What is your PSU? Ensure no thermal throttling in the CPU and GPU, both prone to such issues. Also, try other applications too, to check the overall performance. Also, consider reinstalling the app.
Start Task Manager, stretch it out the width of your screen. On the cpu tab, set it to show logical cores. On the gpu tab, set it to show the individual settings.
Start up Fortnite and play for 5 minutes. Then, tab out to look at Task Manager. Are any of the cores pegged at 100%? Next, quickly switch to the gpu tab and see what the upper left block and memory block show for utilization.
Ok I will try this and report back tomorrow
UserBenchmarks: Game 55%, Desk 41%, Work 32%
CPU: AMD FX-6300 - 52.3%
GPU: Nvidia GTX 1060-3GB - 70.4%
HDD: WD Blue 1TB (2012) - 86.6%
RAM: Kingston HyperX DDR3 1866 C10 1x8GB - 33.2%
MBD: Gigabyte GA-970A-DS3P
these are the results I got
I dont know how to add pictures.
EDIT
nOFzh
How to add images:
Save image to an image sharing site like imgur.com or tinypic.com.
Copy the url of the image (not the page it's hosted at) and use the image tags.
Example:
Code:
[img]https://i.imgur.com/Ie7ywJG.jpg[/img]
^--- Note the URL ends with an image extension (jpg, gif, etc...)
The result
-Wolf sends
MERGED QUESTION
Question from arvindhillon : "I need help with Fortnite FPS"
1400x900 16:10 88.8 res scale
i have recent drivers
MERGED QUESTION
Question from arvindhillon : "My PC used to perform well and completely tanked a few days ago? HELP"
Hey, I wanted to ask some more tech savvy people on why my PC randomly just died a couple days ago, I used to run games like CS:GO 200+ frames (Now 80 Frames), Fortnite 200+ (now runs at like 40) and Rainbow Six Seige at 80+ all ultra(Now Dosen't Run) My specs are AMD FX-6300, EVGA GTX 1060 3GB, 8 GB DDR3 RAM 1866Mhz, Gigabyte 970A-DS3P Motherboard, EVGA 500W PSU, 1TB Hard rive 7200 RPM WD Caviar. Please help my computer used to run games fine now just absolutely tanked.
