I need help!
lillozzer68
288
I clicked on my downloads folder and this popped up
D:\Downloads - Mass Storage is unavailable. If the location is on this PC, make sure the device or drive is connected or the disc is inserted, and then try again. If the location is on a network, make sure you're connected to the network or internet, and then try again. If the location still can't be found, it might have been moved or deleted
I have know idea why this is happening i just booted up my PC and this popped up when i tried to open the downloads folder
https://imgur.com/a/frGXYVw
MERGED QUESTION
Question from lillozzer68 : "I need help!"
actually your D: drive is not showing up.
You have a mass storage device, however it is not mapped as your D: drive.
It could mean that you have some sort of formatting issue.
Go into disk management and see if you can mount the device as D:
No errors were found. Do I create just create a normal folder names Downloads?
