S sonofgrace22 Nov 1, 2018 3 0 10 Nov 1, 2018 #1 My Lenovo IdeaPad isn't up to 1 month, it went off I think due to low battery during BIOS update, and since then the screen hasn't come up, please what can I do?
Solution Phillip Corcoran Nov 2, 2018 BIOS updates should never be attempted on a laptop unless it's plugged in to a mains socket in order to avoid what just happened to you. As previous poster has advised - - contact the manufacturer.
rgd1101 Don't Moderator Nov 7, 2011 73,255 3,846 176,290 Nov 1, 2018 #2 contact lenovo Upvote 1 Downvote
Phillip Corcoran Titan Moderator Sep 7, 2013 25,976 859 120,140 Nov 2, 2018 Solution #3 BIOS updates should never be attempted on a laptop unless it's plugged in to a mains socket in order to avoid what just happened to you. As previous poster has advised - - contact the manufacturer. Upvote 0 Downvote Solution
S sonofgrace22 Nov 1, 2018 3 0 10 Nov 3, 2018 #4 MERGED QUESTION Question from sonofgrace22 : "Black screen after BIOS update" Can BIOS battery be changed if damaged? Upvote 0 Downvote
rgd1101 Don't Moderator Nov 7, 2011 73,255 3,846 176,290 Nov 3, 2018 #5 issue is not the bios battery, is the bios is corrupted Upvote 0 Downvote
