i'm looking to get a ryzen 5 2600 which says max memory speed 2933mhz and an msi b450 pro-m2 motherboard which supports 3466mhz, oc will it run 3200mhz ram, i know i might sound stupid but i'm a complete noob
It's never guaranteed to work , you just research and choose modules that builders are having success with. Also check out the QVL list on the boards site to see tested and approved modules.
Modules that are known to perform well on the Ryzen platform.
i take it you mean what ram am i using, if it is then i don't know yet , i just wanted to know if 3200mhz will work with what i'm getting, like i said i'm a noob and a knob lol
i think i might get this one, HyperX Predator HX432C16PB3K2/16 DDR4 16 GB Kit (2 x 8 GB) 3200 MHz DDR4 CL16 DIMM, Black, i looked on AMD website and this is listed, but would i need to overclock the cpu further as it's listed at 2933mhz
