P pheleaks9 Jan 24, 2019 12 0 10 Jan 24, 2019 #1 My computer wont boot it just freeze in the windows 10 logo is it my hard disk faulty? And i try to reformat but it jus freeze
viveknayyar007 Splendid Apr 25, 2013 3,372 36 28,640 Jan 24, 2019 #2 Hello pheleaks9 If it is a laptop, can you please try hard resetting it as explained here? In case of desktop, please try Clearing CMOS. Hope this helps. Cheers!! Upvote 0 Downvote
P pheleaks9 Jan 24, 2019 12 0 10 Jan 25, 2019 #3 viveknayyar007 : Hello pheleaks9 If it is a laptop, can you please try hard resetting it as explained here? In case of desktop, please try Clearing CMOS. Hope this helps. Cheers!! Upvote 0 Downvote
P pheleaks9 Jan 24, 2019 12 0 10 Jan 25, 2019 #4 Its a desktop sir This is my specs I5 8500 Z370 aourus ultra gaming 2.0 2x4 t force delta 1tb wd black I tried clearing cmos the problem still insist Upvote 0 Downvote
Colif Win 11 Master Jun 12, 2015 67,209 7,040 168,140 Jan 25, 2019 #5 Try running this on HDD, it shows how to create a bootable test tool - https://support.wdc.com/downloads.aspx?p=2 run short and long tests. Upvote 0 Downvote
P pheleaks9 Jan 24, 2019 12 0 10 Jan 25, 2019 #6 Colif : Try running this on HDD, it shows how to create a bootable test tool - https://support.wdc.com/downloads.aspx?p=2 run short and long tests. Upvote 0 Downvote
