Question i need help
Jun 10, 2019
33
hi, my system specs are ryzen 3 2200g,8gb ram and vega 8.How can i see how much v ram i have .And for some reason i cant play any game when i enter fortnite this happen😀X 11 feature level 10.0 is required to run the engine and if i try entering any other game same happen.Even roblox is laging ! Pls help
Is that a LAPTOP/notebook ? If YES, then try downloading the OEM VGA drivers, and other device drivers, including BIOS and firmware etc. Go to the Laptop manufacturer's website, and try the OEM drivers listed there.
Assuming, you have a Laptop, which Model and brand is it ??
Do you have the latest Windows 10 update?
For Windows 10
From Start, type dxdiag in the Search box, and then press enter.
Tap or click on dxdiag from the results.
Check DirectX Version on the first page of the report in the System Information section.
What does it say?
