Question I need help
Dec 25, 2019
I have a problem with my slot ram.
I build a new pc with motherboard MSI B365M Pro-VDH.
For the first boot, I used 4 sticks ram and it works fine and then I'm setting up windows, It stuck on 37% and then I restart it.
after the restart, it won't boot until I check my slot ram.
I got a problem with my slot 3 and 4 it doesn't work anymore.
Is there any solution to fix it?
We're going to need more information. Please list your specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Did you create you installer for Windows 10 using Windows Media Creation Tools? If you can get into BIOS, can you check and see which version of BIOS you're currently on?
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Thank you for your welcome.
My specs":
CPU: Core i5: 9400F
Motherboard: MSI B365 Pro-VDH
Ram: 2666Hz 4sticks
SSD/HDD: WD Green 240G / HDD WD Blue 1TB 7200RPM
GPU: Vega 64
PSU: 750W Gold 80+
OS: Windows 10 Pro
My Currently BIOS Verison: 1.10
Here is my information.
