Question I need help
Nvidia version of that build up above if you desire DLSS. Just swap out the video card and psu with these. ATX 3.1 psu due to the adapter for these Nvidia RTX 40XX / 50XX gpu's.
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor ($385.38 @ Amazon)
CPU Cooler: *ID-COOLING FROZN A620 PRO SE 58 CFM CPU Cooler ($29.99 @ Amazon)
Motherboard: *MSI MAG B850 TOMAHAWK MAX WIFI ATX AM5 Motherboard ($215.72 @ Amazon)
Memory: *TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($92.99 @ Amazon)
Storage: *MSI SPATIUM M461 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($99.99 @ MSI)
Video Card: *Gigabyte EAGLE OC...
what would you change or is this good?
https://pcpartpicker.com/list/CKfDFZ
if if there is something better I need to keep max price the same
If you want help, you should make it easier for those trying to help you, by listing the info in your post. IF I have to go to another link, I won't bother to help. You can see the protocol for presenting this info on most of the posts on this forum. You need to specify what type of software you'll be using for anyone to know what is considered adequate. Hope someone can help.
We're going to need context to the build. We advise users to stylize their thread with info asked of in this thread;
and the community will chime in with worthwhile suggestions.
On face value, I'd avoid ASRock motherboard's. You're over spending on the case and you don't need a 1KW unit for the RTX5070 in your proposed build.
Reactions: Why_Me
You are highly overspending, at the cost of performance. $100 more than what you have there, you could change to a 5080.
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor ($375.00 @ Amazon)
CPU Cooler: Thermalright Royal Knight 120 80.45 CFM CPU Cooler ($34.90 @ Amazon)
Motherboard: Gigabyte B850 GAMING X WIFI6E ATX AM5 Motherboard ($189.99 @ Amazon)
Memory: Patriot Viper Venom RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($92.99 @ Newegg)
Video Card: MSI SHADOW 3X OC GeForce RTX 5080 16 GB Video Card ($1399.98 @ Newegg)
Case: Montech AIR 903 MAX ATX Mid Tower Case ($89.97 @ Amazon)
Power Supply: Thermaltake Toughpower GF A3 - TT Premium Edition 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($109.99 @ Amazon)
Total: $2292.82
Generated by PCPartPicker 2025-05-19 15:26 EDT-0400
Or if that is your absolute max, you can still change to a 9800x3d, an x870 board, and a 5070ti, for less.
Motherboard: Gigabyte X870 AORUS ELITE WIFI7 ATX AM5 Motherboard ($299.99 @ Amazon)
Video Card: Gigabyte WINDFORCE SFF GeForce RTX 5070 Ti 16 GB Video Card ($837.98 @ Newegg)
Total: $1840.82
Generated by PCPartPicker 2025-05-19 15:28 EDT-0400
Reactions: Why_Me
What is the main purpose of this PC build?
My take:
CPU Cooler: Thermalright Phantom Spirit EVO 69 CFM CPU Cooler ($49.90 @ Amazon)
Motherboard: Gigabyte B850 GAMING WIFI6 ATX AM5 Motherboard ($179.99 @ Amazon)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL28 Memory ($119.97 @ Amazon)
Storage: Crucial T500 W/Heatsink 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($132.99 @ Amazon)
Video Card: MSI SHADOW 3X OC GeForce RTX 5070 Ti 16 GB Video Card ($852.98 @ Newegg)
Case: Corsair FRAME 4000D RS ARGB ATX Mid Tower Case ($94.99 @ Newegg)
Power Supply: Super Flower Leadex III Gold UP 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($119.99 @ Newegg)
Case Fan: Corsair RS140 ARGB 95.5 CFM 140 mm Fan ($24.99 @ Amazon)
Total: $1950.80
Generated by PCPartPicker 2025-05-19 16:10 EDT-0400
Reactions: Why_Me and geofelt
I always caution people against getting Full Tower chassis. They are huge and unsellable, because the shipping cost is huge. Only the supplier can get away with it because of their bulk shipping deals.
There are other chassis with support for large amounts of storage if that is your thing that are still mid-towers. If it was only to accommodate the huge motherboard, no need for it.
If you like the look of the 7000D, the 4000D is basically the same thing, but shorter. Comes in several variants with fans, without fans, with a full iCUE Corsair fan setup.
RM1000x is a bit pricey, but a very good PSU.
GF A3 isn't going to let you down, but it is not Thermaltake's best unit. Sadly the PSU market has been very volatile, and there isn't much better than the GF A3 that isn't the RM1000x, sub $200.
Reactions: Why_Me
sorry about not posting correctly. ill try and do better next time.
Reactions: Why_Me
its for gaming and out of the builds that was suggested which one would be best for gaming
You want low profile RAM so that the heatsinks don't impede a dual tower air cooler. The 120mm fan goes inside the back of this case for an exhaust fan.
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor ($385.36 @ Amazon)
Motherboard: *MSI MAG B850 TOMAHAWK MAX WIFI ATX AM5 Motherboard ($218.81 @ Amazon)
Video Card: *Gigabyte GAMING OC Radeon RX 9070 XT 16 GB Video Card ($749.99 @ B&H)
Case: *Antec P20C ATX Mid Tower Case ($86.49 @ Amazon)
Power Supply: *be quiet! Pure Power 12 M 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($119.90 @ Amazon)
Case Fan: *ARCTIC P12 PWM PST 56.3 CFM 120 mm Fan ($9.98 @ Amazon)
Total: $1793.50
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2025-05-20 12:44 EDT-0400
https://www.tomshardware.com/software/windows/windows-11-free-or-cheap
https://www.antec.com/product/case/p20c
Monitor: *LG 27GS75Q-B 27.0" 2560 x 1440 180 Hz Monitor ($169.00 @ Adorama)
Total: $169.00
Generated by PCPartPicker 2025-05-19 17:59 EDT-0400
Video Card: *Gigabyte EAGLE OC SFF GeForce RTX 5070 Ti 16 GB Video Card ($909.98 @ Newegg)
Case: *Antec P20C ATX Mid Tower Case ($79.99 @ Newegg)
Power Supply: *MSI MAG A850GL PCIE5 II 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($129.99 @ Newegg)
Total: $1954.01
Generated by PCPartPicker 2025-05-19 20:08 EDT-0400
https://www.msi.com/Power-Supply/MAG-A850GL-PCIE5-II/Overview
Nvidia version of that build up above if you desire DLSS. Just swap out the video card with this one.
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor ($382.41 @ Amazon)
Motherboard: *Asus TUF GAMING B850-PLUS WIFI ATX AM5 Motherboard ($229.99 @ Amazon)
Video Card: *Asus TUF GAMING OC GeForce RTX 5070 Ti 16 GB Video Card ($999.99 @ Newegg)
Power Supply: *be quiet! Pure Power 12 M 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($114.99 @ Amazon)
Total: $2040.32
Generated by PCPartPicker 2025-05-19 18:23 EDT-0400
what is DLSS
CPU: AMD Ryzen 7 9800X3D 4.7 GHz 8-Core Processor ($439.00 @ Amazon)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler ($37.90 @ Amazon)
Motherboard: MSI MAG B850 TOMAHAWK MAX WIFI ATX AM5 Motherboard ($218.85 @ Amazon)
Memory: TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($92.99 @ Amazon)
Video Card: Asus TUF GAMING OC GeForce RTX 5070 Ti 16 GB Video Card ($999.99 @ Newegg)
Case: Lian Li LANCOOL 216 RGB ATX Mid Tower Case ($102.97 @ Amazon)
Power Supply: Corsair RM1000x (2024) 1000 W Fully Modular ATX Power Supply ($164.99 @ Amazon)
Total: $2189.68
Generated by PCPartPicker 2025-05-19 19:21 EDT-0400
Reactions: Why_Me
