I need help
gmcizzle
944
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128429R
Memory: DDR3 2200*/1800/1600/1333/1066/800
* To reach DDR3 2200 MHz and above, you are required to use with Intel Core i7/Core i5 CPU without HD Graphics and install a discrete graphics card.
When using Intel Core i5/Core i3/ Pentium CPU with HD Graphics, the maximum memory speed supported is 1666 MHz
You can go to DDR3-1600mhz no problem, as long as your memory is rated at that speed. If your memory is rated higher than that, then go higher.
