thedevilitsself
6
i just built this computer, i need a lil help. i cant overclock it past 3.8 GHz, but i was told i could up to 4.5ghz, any suggestions? heres my specs,
asus cross hair IV formula amd 890fx am3 mobo
amd Phenom II X6 1100t black edtion 3.3ghz
2 Patriot 8GB Viper Xtrm Div2 DDR3 1866MHz CL9 2X4GB (16gb ram total)
corsair hydro H60 liquid cooler (cpu)
2 HP 24X DVDRW SATA w/Lightscribe
Kingwin Mach 1 1000w ATX Modular Power Supply
2 XFX Radeon HD 6870 1GB GDDR5 PCIe Dual FN, BLK Ed. video cards cross fired
2 Masscool Hard Drive Cooler Fan
2 Seagate 1TB Serial ATA HD 7200/32MB/SATA-6G hard drives
Serial ATA 4-Port SATA RAID PCI Controller Card
Aerocool FP-01 LCD Fan Monitor/Card Reader
Kingston HyperX Memory Cooling Fan
Thermaltake V9 BlacX Edition Case w/ Dual HDD Dock
any suggestions on what i should change up? or upgrade? thank you
jeremy1183
433
Before thinking your RAM or HDD might be bad try a registry cleaner.
Since the registry is opened so many times when the computer is being used, it can cause such errors. Getting such errors is so common today because a registry almost contains 1 million files that can get corrupted at any time. The operating system of the PC becomes perplexed and it opens windows wrongly making it understandable to read after some time. A registry cleaner can help you in cleaning those registry files that are responsible for producing such blue screen dump errors. With the help of a registry cleaner, it is now able to use your computer without worrying about the appearance of any kind of blue screen error messages.
Fix Blue Screen Physical Memory Dump Error is easy to do with registry cleaner. If you scan your computer it will detect all the errors in your registry and safely remove them.
Article Source: http://EzineArticles.com/4380441
thedevilitsself
6
it happens with and with out games, tried reg. cleaner no luck, just finished redoing my drives and set them to raid, seems stable for now but only an hour into it. still cant get it to overclock, i know it can be done but it wont let me so i reset the mother board to stock settings....
jeremy1183
433
Were you raising your multiplier by increasing it one number at a time and running a stability test afterwards until you could not boot and then adjusting your voltage one increment at a time until it would boot or did you just go straight to 4.5?
flyboy86
134
I have played around with turbo V with my 1090T and I have never had any luck getting it to work so I just stick to OC in bios
jeremy1183
433
Honestly there is really not much need for high OC's if you have a good system to begin with. I saw hardly any difference when I jumped to 4.5ghz on the i5-2500k. Juts brought a FPS in games up around 5-7 more...which I guess is an Ok increase.
jeremy1183
433
Oh, look around some more in that Turbo V program I believe that they have preset OC's that jump by .2 that you can select that it will boost you to instead of just letting the system choose. I know the new z68 boards have them. I believe they start out at 3.6 then go to 3.8>4.0>4.2 and 4.4ghz
