I need motherboard help
jeremy Arias
6
I want to get a i7-7700k but my motherboard does not go any higher than 5th gen so i know i need a new one. I need suggestions for one that meets the following requirements and preferrably under 150, ideally under 120. I need it to have a m.2 slot, support SLI, can be used for overclock, 32 gb ram, has to be Mini ITX, Micro ATX, ATX. it would be cool if it had bluetooth but not nessessary. Oh and can hold evga gtx 1080 ti with watercooling. Pls and thank u
You need a Z270 motherboard for all of those features, its the only chipset that supports overclocking.
Loads of options available: MSI, Gigabyte, ASUS take your pick.
Here's all of your options, take your pick: https://uk.pcpartpicker.com/products/motherboard/#X=0,15116&f=2,7,8&c=119&l=2&E=1,3
These all support overclocking, have SLi, have at least 1 x M.2 slot, support upto 64gb of ram, and will work fine with your graphics card, watercooling is down to your case compatability not the motherboard.
