I need printer to print Legal and Letter at same time.
hachatataasd
Hello, I need some help.
I recive pdf's that are around 200 pages. Within the pdf, are 2 types of documents: legal size (8.5 X 14) and letter(8.5 X 11). I need a printer, or software that will enable me to be able to just click print, and the printer recognizes which page is what size, and it to print accordingly. Setup is not an issue, as I am tech-savy. Im running windows 8, on a pc with some Epson printer. I called epson, and they told me my current printer is not compatible. Not sure, thanks in advance!
Cost wise, a laser printer is cheaper than an inkjet if you have a lot of pages to print. The up front cost is higher but the cost per page is lower.
An HP Laser Let can handle legal size paper on the top "sheet feed" tray with letter size in the standard tray.
I have a printer that can handle both trays aswell. Its just that if I print a whole pdf, it will all be either letter, or legal size. I want it to look in the pdf, see which are what size, and then print the letter size on letter paper and legal size on legal paper
That will be a software controlled thing. Maybe a limitation of PDF.
