i need router help
mallard
32
When i play BF2 and there is somebody using the other computer i will lag extensively.I have a D-Link Wireless router but i'm not using the wireless part, its just wired. Is there a way to limit the others computers usage of the connection or somethin i can do so i can play bf2. I have SBC yahoo DSL by the way
simkeechai
44
who is using the wireless connection, you or the intruder? if you are using the wireless to play the game, i recommend you not to use wireless to play online game, because you will get lag. if the intruder is using your wireless connection, you can log-in to the router and disable the wireless function, so that the intruder can't use your connection :D :)
Similar threads
