Hi guys, i need a new computer ASAP, im actually late on work and it's becomming a problem, tomorrow i want to buy a computer, i asked earlier on forums today for a computer which is work friendly and also gaming based, this is the best build i came to conclusion to for a budget of $1100.
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor ($219.00 @ CPL Online)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($39.00 @ Mwave Australia)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard ($109.00 @ CPL Online)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory ($102.00 @ Mwave Australia)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($67.00 @ CPL Online)
Video Card: Gigabyte Radeon R9 290 4GB WINDFORCE Video Card ($449.00 @ CPL Online)
Case: BitFenix Neos White/Purple ATX Mid Tower Case ($75.00 @ PCCaseGear)
Power Supply: Antec High Current Gamer 620W 80+ Bronze Certified Semi-Modular ATX Power Supply ($109.00 @ CPL Online)
Total: $1169.00
i just found a deal on ebay which contains an i7 cpu at $720 (it also contains similar specs such as 1TB storage, 8gn ram) but the problem is, its missing a video card, if i buy the same video card as the build above, it will be cheaper than the build above, what should i go with? the build above or this deal on ebay? thanks for your time
http://www.ebay.com.au/itm/290955817327?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
EDIT: is that i7 cpu processor better than the i5 cpu processor in that build which i mentioned above? sorry im new to these things
Total: $1169.00
