I need some advice?
TCLucas
9
Is there a website that I can check if my computer components will work together?
These are the links to my components just incase there is not...
Antec TruePower Classic 750w '80 Plus Gold' Power Supply
http://www.overclockers.co.uk/showproduct.php?prodid=CA-204-AN&groupid=701&catid=123
KFA2 GeForce GTX 970 "Hall of Fame Edition" 4096MB GDDR5 PCI-Express Graphics Card
http://www.overclockers.co.uk/showproduct.php?prodid=GX-009-GX&groupid=701&catid=1914&subcat=1010
Intel 730 Series 240GB SSD 2.5" SATA 6Gbps Internal Solid State Drive (SSDSC2BP240G401)
http://www.overclockers.co.uk/showproduct.php?prodid=HD-059-IN&groupid=701&catid=2104
Western Digital Caviar Green 1TB SATA 6Gb/s 64MB Cache - OEM (WD10EZRX) **SINGLE PLATTER** HDD
http://www.overclockers.co.uk/showproduct.php?prodid=HD-379-WD&groupid=701&catid=14&subcat=1279
Creative Sound Blaster Audigy Fx OEM (CL-30SB157000001)
http://www.overclockers.co.uk/showproduct.php?prodid=SC-094-CL&groupid=701&catid=11
CPU: Intel Core i7-4790K 4.00GHz (Devil's Canyon) Socket LGA1150 Processor - OEM (CPU Cooler Not Supplied)
Motherboard: Asus Z97 Sabertooth Mark S "Sabranco" Intel Z97 (Socket 1150) DDR3 ATX Motherboard
http://www.overclockers.co.uk/showproduct.php?prodid=BU-038-AS&groupid=701&catid=6
OcUK Tech Labs - Prolimatech Megahalems Rev.C "Apache Edition"
http://www.overclockers.co.uk/showproduct.php?prodid=BU-004-TL&groupid=701&catid=2330
Three Fan Bundle - BitFenix Spectre PRO 120mm Fan Blue LED - Black
http://www.overclockers.co.uk/showproduct.php?prodid=BU-000-BX&groupid=701&catid=2331
GeIL EVO Leggera 16GB (2x8GB) DDR3 PC3-14900C9 1866MHz Dual Channel Kit (GEL316GB1866C9DC)
http://www.overclockers.co.uk/showproduct.php?prodid=MY-165-GL&groupid=701&catid=8
Thank you loads in advance
TCLucas
You didn't list a case.
pcpartpicker can check but its not always accurate.
I would go with a WD caviar blue drive rather than green.
I don't think you need that sound card as the onboard soundcard on the motherboard is decent.
Yes sorry, I am trying to work out the dimensions at the moment, sorry should have said that. I am looking for something to hold the G/C and H/S with a bit of room.
