Question I need some help i just built my first pc
Dec 18, 2024
I have the phanteks xt pro ultra case and the asrock b650e pg riptide atx motherboard and with the connector thats for the case fans i cant seem to find where to plug it in since its like all daisy chained together and i cant find any other places talking about the same problem.
Page 10 of the manual has a diagram indicating where all the fan headers go. These accept 3-pin or 4-pin fans.
If you have daisy chained fans, it is likely you need only plug in one connector to the motherboard for each set of fans.
If you are referring to RGB headers, you also have both 12V RGB and 5V ARGB headers. These are not cross compatible, confirm your RGB type before plugging that in.
