I have decided to try a triple monitor setup for gaming. I settled on the Dell U2414H monitor. I only have one so far but I will be adding two more shortly. I currently have one GTX 780 but I will be adding a second one for SLI. The more research I do on how to set this up the more confused I am getting. I have a few questions so I will number them to keep it simple.
1. From what I've read using the display port 1.2 on the U2414H and daisy chaining them together will work for extending the desktop but not for surround gaming. Is that correct?
2. If daisy chaining won't work for surround gaming then what is the best way to connect all three monitors? I assume this would work: 1. display port 2. HDMI 3. DVI to HDMI adapter since the U2414H only has display port and HDMI.
3. Next option is 1. display port - top card, 2. HDMI - top card, 3 display port or HDMI - lower card.
Basically is it ok to connect the monitors to both cards or do they all need to be connected to the same card for surround gaming and SLI to work? I know extended desktop will work connecting to both cards but I don't know if SLI and surround gaming will allow that.
4.
4.
