I need some help. Wifi randomly stops working every now and then for computer only
Efjay97
Commendable
Sep 28, 2016
5
This issue only effects my computer, nothing else. Im my home wifi.
My computer will randomly loose connection every so often and then i have to hit disconnect and reconnect to get it to work again untill it stops working again, but every other device using my wifi is good. I ran a virus scan and no issues, i used ccleaner to clean it up. Ive tried a bunch of suggestions, still nothing. Im using xfinity performance pro tier and this is my speed test result, which is WAY lower than what i should be getting.
Speed Results
DOWNLOAD SPEED
40.5 Mbps
UPLOAD SPEED
5.9 Mbps
Also my gateway:
Model Name
DPC3941T
Vendor
Cisco
Revision
1.0
CM MAC
481D70143291
Firmware
DPC3941_3.0p6s3_PROD_sey
Im using windows 7 ultimate
Anyone have suggestions
Also when my computer wifi stops working, it still shows 4 white bars and is still connected, i manually disconnect and reconnect
