V vulture198 Prominent Jul 14, 2017 1 0 510 Jul 14, 2017 #1 I have recently upgraded to an ASUS ROG STRIX Z270E motherboard but my monitor only has a vga port, is there any way to use this monitor via an adapter?
Solution helpstar Jul 17, 2017 Since the DVI is digital only, you will have to use an adpater like: https://www.amazon.com/HDMI-fitTek-Converter-Adapter-Audio/dp/B01ID7W4DW/ref=sr_1_6?s=electronics&ie=UTF8&qid=1500289637&sr=1-6&keywords=hdmi+to+vga or https://www.amazon.com/Rankie-Plated-DisplayPort-Adapter-Converter/dp/B00Z08TZNU/ref=sr_1_3?s=electronics&ie=UTF8&qid=1500289672&sr=1-3&keywords=dp+to+vga or https://www.amazon.com/Adapter-GANA-Converter-Supporting-displays/dp/B06XFR74K2/ref=sr_1_11?s=electronics&ie=UTF8&qid=1500289704&sr=1-11&keywords=dvi+to+vga Aren´t you using a dedicated graphics card?
helpstar Titan Dec 25, 2012 14,854 1,110 84,840 Jul 17, 2017 Solution #2 Since the DVI is digital only, you will have to use an adpater like: https://www.amazon.com/HDMI-fitTek-Converter-Adapter-Audio/dp/B01ID7W4DW/ref=sr_1_6?s=electronics&ie=UTF8&qid=1500289637&sr=1-6&keywords=hdmi+to+vga or https://www.amazon.com/Rankie-Plated-DisplayPort-Adapter-Converter/dp/B00Z08TZNU/ref=sr_1_3?s=electronics&ie=UTF8&qid=1500289672&sr=1-3&keywords=dp+to+vga or https://www.amazon.com/Adapter-GANA-Converter-Supporting-displays/dp/B06XFR74K2/ref=sr_1_11?s=electronics&ie=UTF8&qid=1500289704&sr=1-11&keywords=dvi+to+vga Aren´t you using a dedicated graphics card? Upvote 0 Downvote Solution
