I am building a new PC in preparation for the new AMD Ryzen 9 5900X CPU and AMD Radeon RX 6800XT GPU (probably the AMD original one).
My goals for the build are:
CPU: AMD Ryzen 9 5900X
Mobo: MSI MAG X570 Tomahawk Wifi (because of the great VRMs)
RAM: G.Skill Trident Z RGB F4-4000C19D-32GTZR (CPU optimized for 4000MHz(?))
SSD: Corsair Force MP600 2TB (or equivalent)
GPU: AMD Radeon RX 6800XT
Cooling: 4x 140mm + AIO for CPU (or custom loop for CPU, to be added onto later(?))
Case: Phanteks P600S or EVOLV X
RGB: Some would be nice, but not planning to make a big fuzz about it.
That is what I have in mind. If any of my goals get serious, doubling the RAM and adding more memory is in my future, but that should not do much energy-wise. According to my amateur calculations, this setup should never really need more than 500W, which sounds very low. But, I have no clue what overclocking might add to normal operations. I was looking into the Seasonic Prime TX-750, just to overdo it. But after looking around some more the TX-650 would already be overdoing it.
Can somebody more experienced, tell me if this is a balanced enough build and what PSU would be advisable in my situation? Should I indeed go for a Prime TX or is the difference too small with the Prime PX? I did my research, but it is hard to truly understand what is happening under the hood, without some prior experience. I really hope this build will be the PC I can get that experience with
Thanks in advance,
Bar Weinig.
- Expanding on my video-editing skills (Adobe Ae and Pr & screen-capture)
- Maybe working on some 3D modeling (mostly CAD)
- Gaming
- Probably play around with water-cooling and overclocking (amateur enthusiast)
Thanks in advance,
Bar Weinig.
