vagtasticplastic :
CRO5513Y :
Your build looks fairly balanced overall but a few suggestions i would have without seeing prices:
- Don't bother with the aftermarket Antec A30. The included Intel Stock Cooler will do fine on the locked CPU.
- Consider getting a 240GB SSD over 120GB, this is something you'll regret not doing in the long run and without the cooler you should be able to save enough to do this with the same overall price.
Finally, i recommend putting your build together on here > https://au.pcpartpicker.com/list/. It combines the prices of most the major online retailers/stores and this can be useful for comparing prices and different products at the same price for better performance. Hope this helps!
https://au.pcpartpicker.com/user/ZANDERPANDA123/saved/VhMnHx
My build is $30 cheaper than this build but otherwise, it's pretty much the same
With the 240GB SSD, should I also store games onto it or purely OS and programs? I just don't see how I would need 240 for just the boot.
Thanks for your input anyway, it's comfort knowing my build isn't pathetic
It was just a suggestion in case you want more room for a couple games and what not. If you're happy with the SSD just being for the OS + Apps/Software then 120GB will do just fine. The build is defintiely not pathetic, it'll be a solid Gaming system for the price. An i5 8400 + 16GB RAM + 1070 Ti should max out most games at 1080p 60+ FPS easy. I have the exact same Graphics card and run most games in 1440p with High settings at 60 FPS. To your SSD question, M.2 is a connector type that is directly on the Motherboard (no SATA cable or power) and if you get one that's NVMe, it runs through PCI as opposed to SATA which is much faster, but also costlier. If you're only interested in cheap SSD for boot i wouldn't bother. An NVMe is going to cost you a fair amount more for speed you likely won't notice. As for the build overall, made a few adjustments:
PCPartPicker part list:
https://au.pcpartpicker.com/list/g3cXJ8
Price breakdown by merchant: https://au.pcpartpicker.com/list/g3cXJ8/by_merchant/
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor ($266.43 @ Mighty Ape)
CPU Cooler: Cooler Master - Hyper T2 54.8 CFM Sleeve Bearing CPU Cooler ($26.89 @ Amazon Australia)
Motherboard: ASRock - H370 Pro4 ATX LGA1151 Motherboard ($145.00 @ IJK)
Memory: Team - Vulcan 16GB (2 x 8GB) DDR4-2400 Memory ($222.00 @ Skycomp Technology)
Storage: Kingston - A400 120GB 2.5" Solid State Drive ($38.00 @ PLE Computers)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($54.50 @ Shopping Express)
Video Card: Gigabyte - GeForce GTX 1070 Ti 8GB WINDFORCE Video Card ($599.00 @ PCCaseGear)
Case: Cooler Master - MasterBox Pro 5 RGB ATX Mid Tower Case ($125.00 @ Shopping Express)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply ($89.00 @ Shopping Express)
Case Fan: Cooler Master - SickleFlow (Red) 69.7 CFM 120mm Fan ($12.71 @ Amazon Australia)
Total: $1578.53
Generated by PCPartPicker 2018-08-19 22:38 AEST+1000
- More reliable Power Supply that is also Semi-Modular (Better cable management) for the same price
- If you're insistent on not using the Intel Stock Cooler, i'd take the CM Hyper T2 over the Antec A30. Cooler and quieter.
Just a shame RAM prices are so terrible right now, particularly in Australia as i'm very familiar.
