[SOLVED] I need to choose between three cards and i need your help
Which one would you chose? and why?
  • ASUS GeForce GTX 760 DirectCU II OC 2GB GDDR5 256-bit
    Votes: 0 0.0%
  • Total voters
So, i don't really have a high budget but i got 3 cards that cost about the same in my country.
GIGABYTE GeForce GTX 750 Ti OC WindForce 2X 2GB GDDR5 128-bit
EVGA GeForce GTX 670 2GB GDDR5 256-bit
And i want to get the most performance out of these, which one has the best performance, support and is generally better?
siaan312
Commendable
Jun 15, 2017
171
11
670. although its the oldest card, if you check in gpu userbenchmark it is about 9% faster than the 760
the 750 ti, even in house oc wont make it as fast as the 760 which is about 60% faster
if you decide not to get the 670, I would buy the 760 because it is only a little slower and will get updates for a year or 2 more
Jul 14, 2019
I'll go for the 760 now, as i said, i'm also looking for support. Thanks a lot for the answer!
siaan312
Commendable
Jun 15, 2017
171
11
good choice. just now, the 2gb of gddr WILL be a bottleneck in some games
gta v is a great example. it shows you the gddr amount it will consume and will plummet performance if you go over that even if just a little.
used to have this awesome gtx 580 which was good enough to run all games at medium 1080p 60hz or some games even at 120hz. tho in gta v it struggled bad because of the limited gram.
