J jfriesen Distinguished Feb 28, 2010 3 0 18,510 Oct 2, 2016 #1 I need to convert my Samsung monitor 9 pin male vga to the 15 pin cable (hdmi to 15 pin female. I'm having trouble finding converters for 9 pin to 15 pin. Any suggestions? Thanks.
Solution Saga Lout Oct 3, 2016 I'm either misiunderstanding you or that is one very old monitor and it certainly won't give you an HDMI option. I did find this converter in a UK chain-store though:- http://www.maplin.co.uk/p/9-pin-male-to-15-pin-female-vga-adapter-web-only-l51bt
Saga Lout Retired Mod Mar 31, 2010 24,042 309 69,740 Oct 3, 2016 Solution #2 I'm either misiunderstanding you or that is one very old monitor and it certainly won't give you an HDMI option. I did find this converter in a UK chain-store though:- http://www.maplin.co.uk/p/9-pin-male-to-15-pin-female-vga-adapter-web-only-l51bt Upvote 0 Downvote Solution
