Question I need to figure out which cooler I should get for a Ryzen 7 5800X3D ?
May 31, 2025
25
So I'm on vacation and I went into a McKay's used bookstore which has way more than just books. There was a plethora of tech like old & retro gaming consoles & games. In with that, there was a large selection of used PC components, enough to build 3 gaming systems. In there, I managed to find i the back and get a Ryzen 7 5800X3D CPU still in the box with factory seal still intact for $240. One of my best finds for a CPU that usually sells for around $350 to $450 on Amazon & Ebay. So, now that I've got this CPU in my possession, I'm struggling to figure out a new CPU cooler for this gaming power house.
I'm not sure what CPU cooler I have currently but its a Thermalright brand and is a low profile air cooler. This cooler struggles to keep my overclocked 4.35GHz Ryzen 5 5500 CPU from burning up when putting it through a benchmark & doing anything CPU intensive. Now from what I remember when pushing the Ryzen 5 in a benchmark, it consumes about 80w; the 5800X3D has a TDP of 105W, so the CPU cooler I have aint gonna work.
I have been looking at the Thermalright Peerless Assassin 120 SE as a possible option that could work & fit inside my Vetroo M03 M-ATX case, but i wanted to come here and ask for yalls opinions on what I should buy before I pull the trigger. I would prefer an air cooler tbh but I will consider a water cooler if thats recommended.
What CPU cooler should I buy?
Reactions: geofelt
155mm with the fans in their normal positions and your rams don't force the fans to be mounted higher
166mm clearance in the case
You have 11mm to spare.
Moved thread from CPUs section to Cooling section.
I didnt realize there was a "Cooling" forum so thank you for moving it. Also thank you for the added info on space for the PA-120SE cooler & my case to which I have teamgroup t-create 10L 32GB kit of ram. Do you think the PA-120SE is good enough for the 5800X3D or would you recommend something else.
Twin tower , dual fan with 6 pipes should be fine but you also have to make sure case cooling is up to par with good flow as that can limit air cooler quite a bit.
I got 3 front intake & 3 top & rear exhaust fans. I could 3D print shrouds to improve direction of air flow but it's great. I could go with the Thermalright PA-120D, PA-120 V3, and the Thermalright Royal Predator 130.
So I'm on vacation and I went into a McKay's used bookstore which has way more than books. There was a plethora of tech like old & retro gaming consoles & games. In with that, there was a large selection of used PC components, enough to build 3 gaming systems. In there, I managed to find i the back and get a Ryzen 7 5800X3D CPU still in the box with factory seal still intact for $240. One of my best finds for a CPU that usually sells for around $350 to $450 on Amazon & Ebay. So, now that I've got this CPU in my possession, I'm struggling to figure out a new CPU cooler for this gaming power house.
From personal experience I would use a aio 240 in the top of the case. These chips run extremely hot the 5700x3d runs cooler for air cooling the 5800x3d kind of goes overboard that and pushes the silicone hard. and because of the nature of the v cache being on top of half the cores it acts as a insulating barrier .
DeepCool LS520 is what id recommend.
Im
I'm in the US, I'm not able to purchase any DeepCool products unless on the used market. Also, how long is that AIO gonna last, and what's gonna happen to the CPU if it does fail? That's a game that I don't want to play.
Im
That's the main reason why I'm asking here. Even though an AIO would do a better job in cooling, how long is it going to last. Also, if it does fail, what's gonna happen to the CPU. An air cooler is a lot simpler and if a fan fails, it's still going to be able to be cooled.
I could go with something bigger like the Thermalright RP-130 or JUISHARK JF13K if the heat is a major concern like what beyondlogoc said.
Im
Most aios last year's if you look after them properly never had one break down yet or leak.
Nothing will happen to CPU there designed to shut off when they overheat before any damage does occur.
You can get a air cooler but I wouldn't use anything under 6 heatpipes and even then it may not be able to handle it.
The issue with tower heatsinks are as follows.
You need decent airflow if you have a very power hungry card next to it the heat giving of the tower can heat up the GPU.
also can act like a radiator if you can't kick out the heat fast enough.
An AIO cooler is really an Air cooler.
The difference is where the radiator is located.
The cooling capability is related to the volume of the cooling fins. That will be comparable between a 240 aio and a twin tower air cooler.
Any cooler, air or aio needs good airflow to direct the cpu heat out of the case asap.
Looks count, and some prefer the looks of an aio.
With an aio, the pump is a mechanical device and will fail in time.
Air will permeate through the flexible tubes and in time will reduce the effectiveness and the unit will need to be replaced.
On either, the fan may fail but is easily replaced.
As to noise, it comes from fans running at high rpm's.
A 140mm fan will produce more airflow at lower RPM than a 120mm fan.
On a noctua air cooler, the max rpm will be 1500 RPM which is not noisy at all.
I got 3 intake & 3 exhaust fans in my case, and I currently have a Powercolor Fighter RX 6750XT which does consume a good amount of power but ya know.
If i utilize my 3D printer & create some ducting & what not in PETG, I tell ya what, I wont have any form of air flow & heat issues.
Also like you said, while the 5800X3D is a monster and does produce heat, were talking about one of the best gaming cpu's with a 105W TDP. This thing aint no I9-14900k or I9-13900K. Hell, geofelt has an I9-14900K and he has a Noctua Air Cooler for that CPU (which seems crazy honestly how are you cooling that monster but hey he might have a trick up his sleeve.)
Speaking of I9's & hardware, what is your CPU & cooler, and what temps are you getting in a Cinebench or 3Dmark Benchmark.
Actual fan design does matter too. While a 140mm fan can get more than a 120mm, the shape of the fan blades can have an effect on efficiency, noise, & air flow.
Also I see your setup has a 14900K and a Noctua air cooler. Ik these CPU's arnt similar but what temps are you getting on your system in a Cinebench or 3Dmark benchmark?
if you want to 3d print ducts thats perfectly fine.
the 5800x3d produces alot of heat the issue is the cache stacked on it acts as a insulator. its the reason these chips cant oc as youd fry the cache.
Out of curiosity, I ran cinebench and got a score of 32264.
During the process I had HWmonitor open and observed the temperatures.
Half of the P cores got to 100c. which indicates throttling. The other 4 P cores never throttled. The duration of throttling was fleeting, the processor did exactly what it should do.
My cooler is the Noctua NH-D15S. It is in a cm HAF XB EVO case with two Noctua 140mm front intakes and a 120mm noctua rear exhaust.
The cpu fan ran at 1500 rpm and the case fans ran at 800 RPM so the whole thing was essentially silent.
Ok so I've really been looking more & more, I think I'm going with the Thermalright Phantom Spirit 120 SE. For some reason looking at videos of the 3 versions, the SE did better than the normal & EVO version of the Phantom Spirit 120. It provides great noise & great performance all in a great price. But the other two have better ram compatibility so I will consider the Evo an option as well. I will pair the cooler of choice with Thermalright TF9 thermalpaste for the best thermal transfer I can get.
However while looking for the thermalpaste to choose, the ID-COOLING A720, not the A620, caught my eye as the I9-14900K they were using in Cinebench R23 in tom's hardware testing kept the CPU very cool. However, there are no real tests or comparisons that have been done on the A720. So, I'm giving it a day for yall to pick the final decider.
Thermalright Phantom Spirit 120 SE for $35
OR
Thermalright Phantom Spirit 120 Evo for $52
OR
ID-COOLING FROZN A720 for $70
So since I didn't get a response, I asked around and did some more looking at the 3 and decided to go with the Thermalright Phantom Spirit 120 SE. For those of you in the same boat trying to find a good answer, I'll come back to let y'all know how well the cooler works out.
Reactions: Gigabot
I am going to suggest team air, I am biased after using both AIO and air.
AIO's work well, and look amazing, the fear of leakage is basically not valid today but still a possibility.
But they are a lot more to cable manage, a lot louder in my experience.
They are still a valid option tho.
Air has come a long way in terms of performance, pricing and options.
I would vote for any 2x tower from thermal right.
I am running a royal pretor 130 with ptm on a 7900x that is pbo's to run to about 190w under full load.
while gaming, AAA titles at 240hz 1080p max settings my cpu stays in the 50's-60'sc, and the cooler was $55.
Either way air or liquid you will be fine, it really comes down to personal preference, but I prefer air for now personally. For the lower noise, easier maintenance and set it and forget it mentality.
5800x3d has a tdp of 105w stock, so in reality any cooler you choose will be fine.
Also congrats on such a good find for the price and enjoy your build gg
Just read this, you will be gtg, let us know how it goes.
Yeah a friend on discord that I asked his opinion on the matter recommended me the Artic Liquid Freezer III 360 AIO for my CPU. Well the video that I was watching literally had the AIO as an option and showed that it got 3 degrees lower than the Thermalright Phantom Spirit 120 SE. Funny part is, Thermalright PS-120SE is $35, Artic LFIII360 is $85. $50 dollars more for a 3 degree improvement.
"Well the video that I was watching literally had the AIO as an option and showed that it got 3 degrees lower than the Thermalright Phantom Spirit 120 SE."
3c less than what? if it's less than let's say 80c, it means nothing.
There's always a point of diminishing returns, Tjmax at which temperature it starts throttling is 90c and that CPU is not going to be any faster at 0c or whatever is lower than 89c.
