I need to know if my PC specs will be good for gaming and recording!
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Hi there so im currently saving to buy a new PC for myself and I have already choosen the components but im not to sure if they will be good for gaming editing rendering (ect.)
Here is the link to my all of my pc build: http://pcpartpicker.com/p/T6s6dC
I just need to know if it will be good for what i mentioned above. I am trying to keep this build under $800 USD so if any of you guys would suggest anything better to replace my parts with please let me know.
Thanks!
You don't need a Z-mobo if you don't have a K-CPU.
Don't use a weird RAM amount like 12 unless you want weird stuff to happen, stick to 8 or 16, both won't have problems recording.
That GPU is pretty weak as well.
This build is better balanced and should still be under $800 even with shipping (or pretty close)
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor ($187.99 @ SuperBiiz)
Motherboard: MSI H97M-E35 Micro ATX LGA1150 Motherboard ($79.99 @ Mac Mall)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory ($53.10 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($52.49 @ OutletPC)
Video Card: MSI GeForce GTX 960 2GB Video Card ($194.93 @ Amazon)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply ($29.99 @ NCIX US)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($18.95 @ OutletPC)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($86.89 @ OutletPC)
Other: Corsair Carbide Series SPEC-01 Mid Tower Gaming Case CC-9011050-WW ($38.67)
Total: $743.00
Generated by PCPartPicker 2015-04-14 14:29 EDT-0400
Tried to fit as much as I can into a $800 budget, and this is what I came up with.
The 8320e when overclocked will record/stream/render/edit videos nicely, even being on par with an i7 in highly-threaded applications.
Only downside is that the 8320e will run single-threaded games like Starcraft II worse than an i3 will due to poor single-core performance, so keep this in mind.
The R9 280 will run many games on good graphical settings, and can be used to accelerate your rendering/editing by a good margin.
To top it off I chose an excellent quality power supply which should last longer than the whole build itself, and a sturdy and functional case to keep your components nice and safe.
CPU: AMD FX-8320E 3.2GHz 8-Core Processor ($128.98 @ NCIX US)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler ($34.50 @ Newegg)
Motherboard: Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard ($101.98 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($47.98 @ NCIX US)
Video Card: XFX Radeon R9 280 3GB Double Dissipation Video Card ($159.99 @ Micro Center)
Case: Cooler Master N400 ATX Mid Tower Case ($49.99 @ Newegg)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply ($57.99 @ SuperBiiz)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer ($12.99 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($87.79 @ OutletPC)
Total: $735.29
Generated by PCPartPicker 2015-04-15 01:31 EDT-0400
