I need to make this build cheaper without changing graphics card and cpu :L
Dec 12, 2015
43
Here are my specs:http://pcpartpicker.com/p/WH8BXL
As the title suggests i need to switch some things except CPU and GPU because I don't think I have that much money XD (I'm just a student and use my allowance for saving and my first try building one )
Thanks 😀
I would not recommend losing either the USB 3,0 ports on the case or using such a low performance PSU. (Not low power, 500W is plenty, but low performance)
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($174.99 @ SuperBiiz)
Motherboard: Gigabyte GA-B85M-DS3H-A Micro ATX LGA1150 Motherboard ($50.88 @ OutletPC)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory ($29.99 @ Newegg)
Storage: Seagate Barracuda 500GB 3.5" 7200RPM Internal Hard Drive ($41.99 @ SuperBiiz)
Video Card: Gigabyte Radeon R9 380 4GB SOC Video Card ($193.98 @ Newegg)
Case: Cooler Master N200...
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($29.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($45.88 @ OutletPC)
Video Card: Gigabyte GeForce GTX 960 4GB Video Card ($199.99 @ Micro Center)
Case: Corsair 200R ATX Mid Tower Case ($44.99 @ Micro Center)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply ($55.99 @ SuperBiiz)
Total: $602.71
Generated by PCPartPicker 2015-12-18 08:24 EST-0500
Cheaper and better. The case is good and includes two fans. We just finished a very powerful gaming build in it. http://www.tomshardware.com/forum/id-2852736/build-log-middle-school-jg01-mitx-budget-haswell-gaming.html
PSU is much higher performance and memory is cheaper and slightly faster.
Video Card: Asus GeForce GTX 960 4GB Video Card ($217.99 @ SuperBiiz)
Case: Cooler Master N200 MicroATX Mid Tower Case ($29.99 @ Newegg)
Total: $601.82
Generated by PCPartPicker 2015-12-18 08:19 EST-0500
If you want a lot cheaper, you are going to have to change to an i3 or use a different GPU.
Total: $577.81
Generated by PCPartPicker 2015-12-18 08:25 EST-0500
Total: $583.82
Generated by PCPartPicker 2015-12-18 08:28 EST-0500
I read some articles regarding that gtx 960 4gb is a waste and I should probably go for a gtx 970 soo yeah
http://pcpartpicker.com/parts/partlist/
I chose the Zotac Gtx970 because it's fairly cheap where i live 😀
Just $15 more than the gtx960
