P Pappan Prominent Feb 26, 2017 3 0 510 Feb 26, 2017 #1 Hi am using new inspiron 5000 i7 and i just tried to remove shortcut sign from desktop through regedit after that the system running slowly , is there any solution to fix it
Solution rgd1101 Feb 27, 2017 Pappan : Factory reset with removing all files?is that good? Sure as long as you don't have data or program that you need.
rgd1101 Don't Moderator Nov 7, 2011 74,857 4,242 176,290 Feb 26, 2017 #2 Maybe did something wrong in regedit. What did you do? Upvote 0 Downvote
P Pappan Prominent Feb 26, 2017 3 0 510 Feb 26, 2017 #3 Is there is any way to reset that registry? Upvote 0 Downvote
rgd1101 Don't Moderator Nov 7, 2011 74,857 4,242 176,290 Feb 26, 2017 #4 Pappan : Is there is any way to reset that registry? only if you backup the registry. since it new, might just as well do factory reset Upvote 0 Downvote
P Pappan Prominent Feb 26, 2017 3 0 510 Feb 27, 2017 #5 Factory reset with removing all files?is that good? Upvote 0 Downvote
rgd1101 Don't Moderator Nov 7, 2011 74,857 4,242 176,290 Feb 27, 2017 Solution #6 Pappan : Factory reset with removing all files?is that good? Sure as long as you don't have data or program that you need. Upvote 0 Downvote Solution
